paypal     RegisterRegister   Log inLog in    styles1/4 Mile
Mr Toakley's Mini
Image 4061Image 4075Image 4381Image 4382
AUSTIN MINI 850
Engine:
Vauxhall C20XE 16 DOHC
SBD Motorsport 208 Taper Throttle Kit
Jenvey Ram Pipes
Bosch 708 injectors
MBE Engine Management
SBD Motorsport 4-1 2.5” exit Manifold
ITG Dome Airfilter
FSE Fuel Pressure Regulator
CBS Oil Catch Tank
Nippon Denso Compact alternator
Custom 2.5” exhaust w/Zcars repackable race can
Metro Rad w/Kenlowe adjuster
F20 5 speed gearbox
Quaife ATB Differential
100Ft Cool it Manifold Heat Wrap
ATAC 13mm Red Silicone Hosing
25L Fuel Cell with custom swirl pots
Chassis:
Modified AMT Front Subframe
Modified rear subframe to accept Corsa Anti Roll Bar
Gaz adjustable coilovers
Superlight2 13”x7” Alloy wheels
Advan A048R Semi Slick Tyres
Tarox 6-pot calipers w/235mm discs
Safety devices 6-point roll cage w/custom seat belt harness point connected to antiroll bar
Rear arch wells raised using fiberglass
Exterior:
Deseamed Shell
Fibreglass Flipfront
De-hinged Removal Bootlid
Racetech GP Wing Mirrors
Fuel filler removed and smoothed
VW Fantasia Green With Black Roof
Interior:
SMB Composites Fibreglass Miglia dash modified to fit and flocked Red
ETB instruments Digidash Lite2 stack dash
Cobra Imola S Kevlar Composite seats
Sabelt Harnesses
8 Ball Gear Knob
Sony Cassette player, Sony 6x9 Speaker and Sony 10-Disc changer.
Aluminium handle set, door cards re-covered.
Custom made rear brake bias valve
Vauxhall Corsa Power Steering system with external adjustment, GM ECU.
Figures
Top Speed: 142Mph
Currently all estimates:
Bhp: 208
Ft Lbs: 190
0-60: 5secs
Posted by Mr Toakley on 12am Wed (22/03/06)
FAQ FAQ   Search Search    Usergroups Usergroups    admin Powered by phpBB © 2001, 2005 phpBB Group
